Has anybody found a software that is easy to type out wording or phrases and load to the arc droid? stencil style?
You can try this. https://stencilfy.herokuapp.com/
Sorry, apparently this link is no longer good.
Here is a good link. https://stencilfy.onrender.com/
@cking928 the stencify site works great, but will only save your “stencified” text to an SVG file. From there you can use other systems to create your g-code. I use Fusion360. You also have the option to use another system to save the SVG file as a DXF files which can then be read by the ArcDroid. The only challenge with this route is that often times, the DXF files may be to big for Droid to read in it’s entirety. Good Luck! It just comes down to trial and error.
