Testing with Extreme THC torture test :)
Still needs tweaking but getting there - this is kinda extreme though!
Nice. The THC is a very useful tool.
How did you manage to get the machine to perform a steep cut like that? Were you only using the default settings arcdroid gives you for the THC or did you have to do a full reset and calibration then perform various tests and setting adjustments to get it to do that?
It was a while ago - I didn’t reset anything - just played around with settings - GAIN and velocity comp - higher gain - lower VC .
Do you think the THC would make it possible to cut a small image into a large diameter steel pipe only using a small portion of the pipe?
