THC Explanation of Settings
Hi, looking for some guidance on THC settings. Firstly the THC is working however, I’m a bit stumped as to fine tuning? Does anyone have a link or some guidance as to what function in the THC does what? The reason for the question is that I cut a lot of mainly thinner materials from 1mm to 4mm. Cutting a single shape using the auto level instead of the THC seem to turn out almost perfect every time, but, once I start to cut multiple items and the material starts to distort, the issues start with the height. If I use the THC the distortion is taken care of but the cut quality is very poor by comparison to the auto level as the auto setpoint function seems to place the torch too low. Any suggestions very much appreciated. As I have said everything works but the cut quality using THC is turning out a lot lower than the auto level function.
Interested myself. Just getting started with ArcDroid or anything CNC and there is not much about THC with the ArcDroid.
Hi I havent had any responses. Have you had any luck?
No, no responses, might have to try to contact one of the youtubers who are using it. There arent any instructions that I know of.
