THC on Cutmaster 82 (SL100 SV Torch)
Hello, new here and new to Plasma as a whole. I have an ArcDroid with an X2 kit and a water table. I was wondering if it is possible to get THC on a Cutmaster 82 Victor (SL100 SV Torch) with the ArcDroid, I don’t believe I have a CNC Port; so I am wondering If Ill need a Voltage Divider 50:1 or not? Thank you.
I just hooked up a Cutmaster 82. I have the SL60 torch on it. Setup was pretty easy. I picked up some Tee connectors to splice into the signal for start/stop inside the machine and some 18ga lamp wire.
There are approx 8-10 blue wires inside the power unit. I checked the continuity through the trigger switch down the ATC cable and then the blue wires match them.
Hope that helps.
