Does any one know the rating of these contact ie to start a different type of machine
Might consider using the Droid contacts to drive an auxiliary relay. That way you can spec whatever current rating you need. This would prevent any possible damage to the Droid.
Hi yes that was thinking of doing
Say running 12 volts to close a contractor with higher capacity contacts
The relay is rated at 3A 24VDC
