What is the current rating of the torch on relay? Will it power a pneumatic valve or do I need to use a Arduino interface?
Can THC be used with the X2? I found a thread but there was no definitive answer.
@Illbebetter
Torch on relay is rated at 3A 24VDC
THC and X2 can work together but great care needs to me taken to isolate and ground the table to avoid weird voltage cross talk. Best practice is if either is unneeded then disconnect during cutting.
Thank you Andrew.
I sent you an email requesting the THC code. I haven’t even powered my arcdroid up yet as my power is still off from Helena.
Use quick connect for each line that way you don’t have to connect, re-connect each time you need to switch.
