Titanium 65 Fault
Just starting to get fired up for the first time. Imported a simple weld tab with a 1/4 hole.
the torch will make the first cut every time then lift and move to the second cut and probe and not ignite then the plasma cutter goes to fault code F07 which is “Electrode or nozzle failed to reset”. I am using the Plasmadyn PTM 60 for the Titanium 65. Any help would be greatly appreciated.
Chris
Remove your consumable cap and see if you have two contacts pins on your torch if so, those probes are your issue make sure they are clean then reassemble and see if you falt if so, you may have to bypass the probes their other posts with that issue that can help you. Also make sure you are grounded to the part not the table.
