I download a cut gcode cut file from the forum and when I went to cut a previous file that I cut a few days ago it would not cut properly so I went back and looked at the tune and had noticed that all the settings have changed and it will only cut the out perimeter and at the end of it the torch moves all the way up and stops. I trying to get my setting back to the point it will cut again with a little fine tuning. Most of the material I cut is 3/16 mild steel. Anyone willing to share their settings, I’m using a Everlast 60s
For 3/16” steel
45A, .06” cut height, .15” pierce, .5 sec pierce delay, 85 ipm cut speed
Should be a good start. Can probably up the speed some.
