I just did the latest update. It has been months since I have done the last one. Now it has an extra white line across the screen.
Try calibrating your screen it looks a little off center
I’m not aware of a way to do that.
That is for the touch pressure. Mine works the way it should.
Seems my problem is in the UI itself…When updating with any version, that line is there, even when the screen is red.
Try going into Settings → Touch Screen → Flip Screen.
Does the line stay in the same place or does it move?
Stays in the same place
If it doesn’t effect your projects, I wouldn’t worry about it.
I would like to find out why. It is less than a year old and shouldn’t be doing this.
You could try and reload the last updates if the line goes away its in the programming not the unit.
I have done that as posted earlier.
@Cmsmoke
Hey Tony Send us an email or give us a call when you have the chance. info@arcdroidcnc.com 705-828-0470
It’s entirely possible that you have a failed pixel line on your screen
The update is probably coincidence, but there is a couple things we can try to confirm.
Will do, Andrew…
Thanks,
Tony
