I was looking at the pictures of the X2 base and saw a wiring connection below the existing screw connections. Will I have to drill a hole in my ArcDroid to connect the X2 wiring?
Maybe you should watch the x2 explainer video. There is no wiring. It is a framework that allows you to move the arcdroid and index it to the frame so that you can cut across a larger than standard drawing box. the functionality for the x2 indexing is how you design your part and options on the screen if I remember correctly.
