I have my Arcdroid setup on a down draft table that put the Emergency Stop button where I can’t get to it when I might need it the most. So to solve that problem, I wired up an additional E-Stop so I can move it around to where ever I need it. The E-Stop controls the receptacle that the Arcdroid plugs into, so I also use it to turn the Arcdroid on and off. The base of the moveable E-Stop has a small rare earth magnet that will hold it to any steel surface available, which make it easy to get to when I have a large sheet of steel being cut.
