Another sign - Project no.5 old saw blade
95% success on this one… Didn’t allow for the kerf in places Excess water splashing was intentional to keep the heat down. Worked well too.
Nice work. I like it
What is the elevation distance from the bottom of material being cut to the surface of the water below?
A reasonable guess would be around 50-70mm or 2"-3" - the slats are 25mm / 1" - the 70 PSI from the torch is the main agitator
Thank you for the reply. I am about to build my own Arc Droid cutting table have to determine what elevation to locate my water pan.
I don’t think it matters too much, anything up to say 5" below the slats would cause splashing just make the tray 3 to 5" tall and then mount it 1/4" under the slats and you will be good.
The splashing helps with the smoke a bit but also keeps the work cool - The “smoke” in my video is actually steam. I could pick up the saw blade straight away after it was cut as it was only warm not hot - zero warping from all that heat input
