I’ve been using my arcdroid for a while now but for a few weeks some files stop cutting right in the middle and throw some weird errors. Also sometimes the arcdroid stops moving and a error shows but the torch keeps cutting until I hit the reset button.
Also when doing a dry run there’s no issue. But when it’s running the path on the screen the location of the torch head gets glitchy.
That’s electromagnetic interference from your plasm a cutter…
Let me guess, Primeweld Cut60?
You will need to make sure your cables are well separated and if possible you need to ground your table to House ground (green wire) or maybe water pipe
I just built a new water table and had the cords kinda on top of eachother.
Thank you for your response. I have a small garage shop and there was no way i could fit a plasma table even though i wanted one. With the arcdroid i have a CNC plasma that i can literally store anywhere.
