Hello from Austria!
I own the arcdroid for about 2 weeks and it worked well until now. I have a thermal dynamics cutmaster 101 attached.
The problem: it cuts for example the first hole at the end of that hole the nozzle stays down a bit longer as usual it moves up slowly an to the startling point of the next hole then it freezes, the arm can not be moved until I switch arcdroid off and on again. I don’t think the cutmaster is a HF machine since the smaller ones aren’t and I had no problem until today. Yesterday I updated arcdroid (both firmware and simple trace) and it still worked
Am I wrong and the cutmaster 101 is HF? Or what can cause this problem?
Thanks for your help
@lobbo
Is it possible you have the “off delay” set really long?
Can you share your Tune settings? And perhaps a video of the behavior ?
If i do a dry run without torch on it works
I downgraded the firmware and now it works
