Posted in the fb group and sent Andrew an email. I’ve been out of the shop for 2 weeks, machine worked great when I left. Went in today to cut out a few brackets and ran into this issue.
Load file into machine, go to cut, machine cuts first cut, but when it goes to lift to move to next cut, machine freezes and reboots. If I push start with cutting turned off, it runs the entire file. This happens regardless if the plasma is on or off. Things I’ve tried with no luck
Turned off plasma cutter. Still happens
Removed trigger wire from arcdroid, still happens
Removed plasma torch from machine, still happens
Ive re updated firmware and simple trace with no change
Went into settings and restored everything to default, no change
Happens with any file, including a simple trace circle. Any ideas? Pulled the back plate off, nothing seems to be wrong, no loose wires, nothing looks bad.
Again, worked great 2 weeks ago when I left the shop. I’m the only one who has access to the shop, and shop is climate controlled.
Here’s a video of what it’s doing.
