Just run into a problem to day (typically ) cutting the last part of a project.
Been using the droid for about almost 10 months with out problems… But today it just started rebooting/resetting after its finishes its a cut.
It will dry run fine, but after enabling the cutter it has a problem. Even without a plasma connected (so as to rule out HF) you can hear the relay for the cutter fire it then goes through the motions but 30sec after as you hear the relay click to switch the cutter off it does a complete restart all the time every time, since switching on today.
