I want to cut a dune flage whip mount, its just a circle and a rectangle combined. Is there a way to make it so the inside of the circle does not cut?
I don’t understand what your asking or trying to do…….
Maybe a picture or drawing?
I see says the blind man……
I don’t think you can remove part of the circle… but,
I did parts just like it with a different train of thought. Say your part is 2”x 4”, with 1” radius on one end. Simple Trace a rectangle 2”X 5”, designate the corner radii as 1” then cut 1” off an end to square off. Wastes a little bit of material but gets the job done.
If your working off a good straight edge on your material you could do the same round corner rectangle with one radiused end beyond the material.
This would definitely be a nice feature. Hopefully it will get added soon.
I know this is an extra step, but Sheetcam has an excellent shape library in which you just add the parameters and save. Then bring it into ArcDroid.
