When trying to save a trace file I am getting “Couldn’t Create File. Error: 0x 7”. I have tried the onboard storage, as well as saving to a USB with the same result. I should mention I am trying to tweak the dimensions on a square created using trace, then saving again. I did submit a this issue to the “contact us” option on the website, but maybe someone else has overcame this issue?
If you go into Settings → File Name, what is it set to currently?
