I have two designs here, one loads perfectly fine and is a successful cut. The other is showing the “travel paths” as cut paths so it will cut everything from start to finish as one solid cut if I turn the torch on. Haven’t wasted any metal on it yet but why is the ship drawing making the travel paths betweeen cuts orange instead of white as it should be? I haven’t done anything different in Inkscape between the two drawings.
I did update Simpletrace and the firmware and that seemed to fix the travel path issue on the ship file but now it says the file (among a couple others) that loaded fine before but now won’t load the file and says its too big. Is there a way to make the storage on the ArcDroid larger instead of the update files using up all the space needed to load a file?
Are you saving all your cut files on a USB? Also go through your files and get rid of all your junk files.
I have a USB drive specifically for ArcDroid updates only and use my other USb drive for cut files. There shouldn’t be any junk files even been loaded to the ArcDroid. Only two simpletrace updates since I got it and two firmware updates. Only other things have been cut files on one USB drive designated for cut files only.
