I am using a smallish compressor for the plasma cutter on the Arcdroid, as such I have to pause the current job sometimes to let it catch up.
I would love to be able to add a pause command to the gcode, I’ve tried M25 and M0 but they don’t seem to do anything. Does anyone know a gcode pause command that works with the Arcdroid?
You can increase your torch off delay to get a pause after every cut.
If you want to pause with gcode, M0 (Stop) is not implemented in SimpleTrace, but G4 (Dwell) is.
Custom gcode must be wrapped in a “raw gcode” block like this:
; raw gcode
G4 S30 ; pause for 30 seconds
; end raw gcode
Space and capitalization matters for the block start and end, and gcode must be in all caps.
Thanks, I’ll give that a try. Don’t suppose there is a gcode to pause the same as if the use had pressed pause. So stays paused until user presses pause again.
