General Inquiry - Considering Purchase
  • I have a pretty functional shop environment, with full size 5’ x 10’ plasma tables and lots of other Metal Fab machinery.
  • I like to travel slow and long trips, pull my travel trailer… and would like to setup to do some stuff remote.
– I am curious about how other folks are powering an Arcdroid remotely (in the field) …
– I am also curious about using Oxy/Acetylene (or Oxy/Propane)… with the arcdroid.
Works great with oxy fuel since there are no belts on the arms, I use a fan to blow some air to keep it from getting too hot.
There is a slightly steeper learning curve inherent to oxy fuel since the travel is slow and warpage is high if not accounted for.
I use the same torch as my track cutter mounted a the same offset as my plasma so no calibration required.
2strokeforever Please add pics
