Getting Started
So I’ve ordered an Arcdroid, currently have a Hypertherm 45 XP and I just ordered the CPC port (428653) upgrade, the SYNC cartridge adapter (428951) for my handheld and a smartsync 45a mechanized nozzle (428925). Does that sound like all I need to get started and be able to use THC effectively? Thanks for any advice, looking forward to receiving it and getting started.
Lastly is there a library of files somewhere online to get started and what is the most affordable drafting program to use? I went on the Fusion 360 website and it looks VERY expensive for a hobbyest after the first 30 days.
Thanks again!
Fusion has a free diwnload for hobbiest. And plasma spider has a lot of free dxf files and ti join is only $20 or $25. I have used sime off there but mostly. Use simple trace ti fix broken stuff or to modify.things or copy a friends mods that he shared all i do is use simple trace and walaaa a part just like the one he payed $200 bucks for.
Anthony in Alabama
Well I ordered the CPC port for $200, hopefully it was required to run the xp45 with the Arcdroid.
Thanks for the info @Joatmon, Ill definitely look into that free version of Fusion360, as well as the other resources you listed.
I ordered my 45XP with the port installed. I ordered the cable for it afterward. Two of the wires are used for the THC on the Arcdroid. I have not yet used THC. I am getting some more experience before adding any more learning curve. You will need to do the torch switch bypass, unless you ordered the machine torch with your cutter.
What was the cable required (part #)? Is it a hassle to remove the torch and use in manually when needed? And I’ll have to look for a video on the “torch switch bypass”…I looked into the machine head but it was pretty pricy!
Thanks for the feedback.
Hypertherm Machine Interface Cable w/ Voltage Divider, 25’ - 228350. I have the 50’-228351. I did the bypass on the torch lead close to the plasma unit. I figured if I had a warranty issue, I wouldn’t be sending the lead and they wouldn’t question the modification.
Thanks for that, just ordered that as well. It’s starting to add up all these costs. $200 For CPC Port, $200 for 25’ Cable w/voltage divider, $160 for cartridge adapter and $70 for mechanized nozzle!
Hopefully that’s all I need and it isn’t to much more to get it up and running.
Thanks for all the advice @Cmsmoke
