Hey all! First, if this violates some rule, I understand if you have to delete it and/or scold me.
Second, my youtube channel is coming up on 1000 subs and I’m going to be giving away an adjustable inline voltage divider that I made. I can’t guarantee it will make all your THC problems go away but it helped me get mine up and running. It will work in conjunction with the CNC port on your plasma cutter, either raw voltage or 50:1 or anything in between. Or can be wired direct off the + and - terminals in your machine.
You can check out the video here for details and to enter if you so choose.
https://youtu.be/RWhzk_LpEnY
Cheers all and good luck!
Jason
