NEW RELEASE OF SIMPLE TRACE and MAIN CONTROL FIRMWARE
@34787Bob
Whoops I must have deleted it last time I set up the latest update.
Sorry about that. it’s been corrected Previous version is there now
I also had the Probing error and to solve it I needed the raise the height of the torch above the material before clicking run. It seemed if the Z axis didn’t have far to travel down while probing then it would give me the error message.
@Rcutting @Inhabor @34787Bob
Probing Error has been found and beaten in to submission
New versions of Both Simple Trace and Control Firmware available on our website. Should solve everything.
Thanks for the feedback guys! This is how we improve!
Great news! Thanks Andrew, I’ll give it a try.
Hi all,
I have updated the firmware to the latest version, where can I find the description of the new parameters (Vel Comp, Auto SP, Setpoint) added to the THC function?
Thank you.
We received our Arcdroid on june 5th. IS this update already intalled on our machine? Or do we still have to do it?
@LucD-B
Latest firmware released 6/15 so you’ll need an update. You can check what is installed on your Droid by tapping the Arcdroid logo on the screen five times and selecting the Version Info box.
Ok, thanks. I’ll check that first thing tommorow morning
Micro sd is for your firmware downloads does not use a standard size sd card.
Us a usb stick 32gb or less in fat32 format for you simple trace downloads
