Problems with the last simple trace download
On DEC. 8/2025 I downloaded the simple trace update . Well when I loaded it into arcdroid things went bad. First recalibrating was a extreme pain failed every time. I checked everything over and over again. Then just for giggle’s I plugged the X2 into the droid and did the recalibrating again. This time it worked. Butt, when I went to use the auto level feature it would pick up the 3 points fine. But would not allow me to turn it on it just stayed off . I got up set and reloaded the previous simple trace download and all works fine. And recalibrating was a breeze no problems at all. And auto level works fine to. What’s up?? I will keep eye out for other post on this. ps thanks for reading .
@perryharris I had the same troubles with toggling Auto Level on and off. It started with the November update. I emailed Andrew last week. He just confirmed today that the fix is in the latest December 11 SimpleTrace and firmware updates. I’ll update tomorrow to confirm the correction.
