New user, adjusting/editing saved files
New arcdroid user, and I’m absolutely loving it so far. I do have a couple questions about editing saved files.
I’ve traced the cut I want, and saved the file. I want to make some adjustments to some hole locations, like moving them a few millimeters in any direction, but I don’t want to have to retrace my entire template to move some of the holes.
The same with the outside cut perimeter, I’d like to modify a couple of the perimeter points, without retracing the entire template just to change a couple of points.
If adjusting them is possible with the onboard arcdroid software, is my original file still saved, or once I edit the original file, will it overwrite that file with the edited one?
I would kind’ve like to keep my original file safe, in case I like my original design better than my edited one .
I’m using my droid to cut floorboards for ATVs, then bend them with my brake press.
I have saved trace files as a DXF and opened them is Fusion and made a new drawing using the trace as a template.
Yep editing in simple trace is easy.
load the file go into trace zoom in on the shape you want to edit. tap the shape, it’’ll turn brighter red. Then hit the edit button. (pencil thing) you can then change the X and Y coordinates or change the diameter of the hole etc.
CheersAM
