Noise when lifting cutting head
Hi - have now had the Droid for some time and still marvel at what it can do. One unintended feature mine has is that it makes a squawking noise when it lifts the head to commence a new cut. The noise is coming from within the main body area - not the arm.
Has anyone else experienced this and what is the fix?. Thanks
@Ian
Yup common with some of the older units
Quick fix go to
Settings ->Machine Settings->Max Acceleration-> Change the Z value to 25
Next go to Settings-> Machine Settings → Driver Current-> Change Z value to 1400
Early defaults were a little aggressive and depending on the torch head you have it may just be struggling to keep up speed wise
If the problem persists give us a call
Thanks Andrew, I changed the first value from 30 to 25 as you suggested. The second value was at 1400. Unfortunately it made no difference. Do you have any other suggestions? Thanks
@Ian
Give us a call 705-345-5702
You may need a Z replacement kit
Thanks Andrew - I am in Australia - so time zones will be an issue. I will try and text you my email address and we can pm via that media.
