I just received my unit and trying to do the first calibration. when I got it, it would home. I went through all the steps and also have watched the video before doing it. after performing the calibration, the unit tried to home and it just puts the arm straight out and gives an error. I have tried resetting it also changing back to default settings. I have tried the G code G28K and I’ll give the same results. Also updated the unit.
I worked with tech support and found a limit switch was causing the error. After some diag and some more checks it was determined that the motherboard was bad. I have one on the way
