Saving pattern
how do i save a pattern to a thumb drive or SD card I created.
Plug your formatted USB drive into the controller and press the Save button. Icon looks like a floppy disc.
First off I want to thank you for all the help you have given me, that was the the problem I was trying to load the pattern on the thumb drive instead of the card now I have another problem I’m cutting patterns out of 1/8” steel and they come out perfect but now I’m trying to cut 1/4” and pierces but then alarm shows up and it stops cutting , I’m using an Arcpro 55 which is supposed to be compatible with the Arcdroid l changed the feed settings and no matter how slow I run it, it keeps going into an alarm, l would hope it would be able to cut 1/4” steel.
Are you getting a fault on the Droid screen or a fault on the plasma cutter itself?
Yes on Droid “volume init. fail
I have never seen that message……. Is this the exact same trace you successfully cut in 1/8” ? You just made tuning tweaks for 1/4“ ? Maybe post a pic of your “tune” settings .
Tried a dozen different feeds and orchard delays and everything else also new consumables it only just pierces and stops the torch runs for about 10 seconds and shuts off, now it won’t even cut 1/8” , it traces it perfectly but when I run it with the torch it just pierces and stops an the “volume. Init failed “ pops up on the screen.
Also it’s the same trace I just need it in 1/4”
For 1/4” mild steel I would start my tune settings at,
@45A. Cut ht .06”, initial pierce ht .15”, .6 sec pierce delay, 50-60 inch/min cut speed.
I don’t see your settings causing a Droid screen fault though.
Maybe for kicks try a simple trace pattern like a square with a hole to see if that runs with 1/4” ok.
