Can I use my old hf plasma cutter in the same room as the arcdroid?
Probably not at the same time on the same piece of steel that the Droid is running a routine on……
About ten feet away and my Droid will be tuned off
No issue with that. If the Droid is powered down all is good.
I was powered down and unplugged but still had to reload updates they may be unrelated but I’m going to be far a way next time.?!
