It occurs to me I forgot to announce this on the Forum.
One of the most frequent questions we get asked is “Are you gonna make a bigger one?” and the answer is … Sort of.
Introducing the ArcDroid™ X2Large Cut Indexing System.
(preorder now for shipping beginning Nov 28th)
The X2 is an upgrade to any existing ArcDroid™ that adds almost another 600mm (23”) in the X direction to the overall cutting envelope without sacrificing the ease of use and portability that you’ve all come to know and love. Using a custom encoder and a set of slide rails the X2 allows you to stitch together cuts into one big cut easily. Simply slide to the left and cut the first half then slide to the right and cut the rest. The X2 system will do all the math for you!
@Andrew How does this work with Simple Trace? If I was using a 40” template to trace, what is the process to split it up?
How long to you anticipate the introductory price to remain in effect?
Thanks for all you do!!
Hi Andrew,
How does this work for CAD drawn files that are up to the 1220mm width?
Is there an sheet am update or something to split the file?
Or does the split happen once you load the cut file to the arcdroid?
I love this idea and keen to order one, just would love to hear a bit more about how to use it
Yes the Split is done on the ArcDroid no need for SheetCAM of Fusion Updates.
Use is simple.
Press X2 button and slide to the left.
Load/Trace your oversize drawing and align it
Pres X2 again
Choose split point by moving/rotating a cursor
Start the first cut as normal.
When ready to make second cut push X2 again
Slide machine to the right and Run the second cut
