What size box section
Hi thanks for adding me. I’ve got an arcroid in the post with x2 but wondering how do you level the arcroid if cutting shapes into box section, for example if I need to cut 50mm box then do I need to place 50mm box under the arcroid using g clamps
Could you clarify, are you talking about square tubing?
Yes square tubing, I want to build a table this week but can’t get my head around how to work out best way to adjust height
If you are cutting something that is thicker than the Z travel on the Arcdroid, then yes you can space up the Arcdroid with another piece of the material that you are cutting.
Make sure that you clamp the Arcdroid down and make sure the arm clears your clamps when the Arcdroid homes itself.
Happy cutting!
Thankyou, I can’t wait to get it I’ve always cut everything with cutting discs. I’ve never even used a plasma cutter so no doubt I’ll be asking loads of questions on here
