I’m having an issue with the z height, cutting height on my arcdroid. When it probes to find the material, the cable for the z height goes completely slack and comes out of the machine. No matter how I adjust the probe offset, it occurs all the time. The torch then drags across the material, without the correct cutting height. Following are a couple of videos of the issue.
Looks like your droid has had a bunch of use. Has taken some slag by the looks of it. Run the Z all the way down, then pull the Z head up with your hand and hold it. With the cable slack you can inspect the plastic hatch for free movement and see if the switch has a good click to it.
It looks like your setup has the Z working at it’s lower limits. You could try remounting the torch sled to another set of holes so that it is not traveling so far down and has better spring tension on it.
Could well be the switch itself.
I’ve been cutting aluminum with it, and the aluminum powder gets all over it during cutting. It just needed a good wipe down, it looks cleaner in the following videos.
I did try lowering the torch on the mount, so the z axis isn’t traveling so far. Unfortunately it’s made no real difference.
I bought the arc droid about a year ago, and it’s actually worked like this since new. Since this is my first time using a cnc type machine, I had no idea how it was supposed to work when I started out. Now that I have some time under my belt, I’d like to get the cut height so it’s actually at .060", if I can get it to work it’s usually double that, no matter how I adjust the cutting height in settings. Probe offset has been calibrated, and it’s right on.
The plastic hatch for the z axis switch does move freely, however, if the cable moves off to the side, like when the arm is extended and to the side of the machine, the switch does not always click, and that’s also when I usually get all the extra slack in the cable during probing.
He’s another video after adjusting the torch mount to bring the z axis to it’s upper travel.
This is a photo of what I’ve had to do just to get it to probe without all the slack coming out of the cable, however my cutting height still does not work correctly. It’s simply an aerosol can plastic cap, that I set around the cable, to help keep the cable upright on the switch. Obviously I shouldn’t have to do that.
And one final video of how it probes when the plastic cap is on the cable.
Maybe check to see if there is a bunch of slop in the Z. Look for backlash. Use the knob to bring it down, one click at a time. Stop and use the knob one click up and then down one click to see if it is at the same spot. Maybe the Z nut has worn out…. I’ll look thru my paperwork to see about cable adjustment, I had to replace the Z nut several years ago.
