My apologies if this has been asked/answered.
I’m awaiting the delivery of my Arcdroid, and would like to get a mount worked up for my table.
Could anyone share the baseplate dimensions with hole locations, and the material thickness of said baseplate?
Many thanks!
Mike
Thats terrific thank you Andrew! Can you please tell me what the diameter of the reference holes are at the front of the plate for the calibration triangle? i assume they are 10 mm holes full formed but i hate to assume and just from the drawings the reference holes seem off center from the front mounting holes. Not that they have to be but these are the precise dimensions i need most.
thank you
Ken
Excellent! Many thanks Andrew!
The topic is very helpful, I thank you deeply. Could you tell me where the axis of the arm is located?
I’ll try to build this to cut over entire planks.
Hello Andrew. Would you have the dimensions of the the exact locations of holes that are used for positioning of the calibration arm? I’m looking for the locations relative to CL all 4 of them, and the exact diameter used.
I would like to make a larger base that will include lift handles or lift points. I need to make sure it extends far enough past the potential motion of the arm so there can be not crashes (especially long on the right side) and a little bit longer on the left side as well to make sure I don’t accidentally grab and disturb the cords on that side.
