Hello, new user here, but seasoned machinist and fabricator. Anyway, I bought the arcdroid and hooked up to my Harbor Freight Titanium 65 amp machine. Works great. But I wanted to put a CNC style torch on it, so I hop on the Amazon and buy what appears to be a primeweld clone to their 60 amp torch. My issue is the factory torch for the titanium has 6 wires in it along with the power lug. 2 for the pilot arc, 2 for the trigger, and 2 for what I believe to be the shielding cup sensor. The CNC torch only has 5, and I am wondering if it’s piggy backing one of the leads from the trigger for the shielding cup. Has anyone run into this? When I turn my machine on with the CNC torch plugged in, I get an F03 error which is the shielding cup sensor. I have swapped the pins around for the pilot arc and trigger already to match the harbor freight torch wiring. attached is the picture of the CNC style pin out. Note that I have changed the pilot arc pins to 5&6 to match the harbor freight torch, 1&2 are the same on both torches. The harbor freight unit uses on 8&9 for the shielding cup .
