Maybe some not closed loops
I have had something similar a couple times. Restarting software and doing the gcode again and it went away.
Hi Jim.
When you say restart the software, what exactly do you mean?
Turn it off and on again, or more of a reset?
Thanks.
I was using Fusion 360. Basically just closed/opened app and did the gcode export again. Probably restarted the 'Droid too.
start over with a couple very simple drawings so that you have a chance to read the gcode in a text editor and the gcode is simple enough to comprehend that it looks “right” or if something looks really weird with extraneous code.
