Hello,
I recently bought the arcdroid from a dealer here in sweden. I have just finished building a table for it.
Cheers from sweden!
Looks good but make sure no sparks hit the controller screen as they melt it and render it useless.
@mattm
Nice!
You might want to add some more slack to your torch cable as too much lifting up on things by the retraction cable can cause false probe.
You want your cables to very neutral at the point they connect to the ArcDroid
Hi!
Thanks for feedback, im a beginner in the world of cnc. The block that lifts the torch is not very strong, it just keeps the kable from beeing all over the place. I also added ballbearings to the arm that holds it so it can swing freely from side to side as the arm moves around. The first test worked without any false probe.
//M
