How do I resize a object to make it smaller I’m scarred to be my normal self and start pushing buttons
Load your program onto the Droid. Tap “Trace”. Tap first blue tab, has two triangle symbol.
From the screen that comes up select “Scale”. If you want 1/2 size smaller change the 1.00 to .50. If you want 1/4 bigger change it to 1.25
You also need the current (both) firmware versions
Thanks
Now I got to find steel cheaper than 380 a sheet of 1/4 inch
