Plasma stops half way through cut file
Hi All
Advice please.
I have made some G code files on sheetcam from the DXF files. When I try cutting them the plasma stop firing halfway through cut at the same place every time I cut. Any advice welcome
Sounds like the torch is too high and arcs out at the same spot each time. what cut height are you using?
