When I slide my arcdroid to the left with x2 it slides right on the screen and vice versa. Seems like a simple fix. Maybe moving aluminum rail to opposite side? I am standing behind the arcdroid when in use. Thanks for any help.
Is your screen orientated the same way as your arcdroid.?
I think I remember in another post regarding the same problem, that I believe Andrew suggested that the aluminum encoder rail may have originally been installed up side down. You may want to try turning it 180 degrees and see what you get for results. Mind you, I am not saying this will solve your problem, it just that I am so new to my Arcdroid, I have read almost every post on this site to gain as much knowledge as I can regarding this wonderful piece of equipment. Hopefully this will resolve your problems. If you do try my suggestion, post your results so others may benefit
